Change log versione 2.0.4
Changes between 2.0.3 and 2.0.4:
Audio Output:
* Improve playback synchronization with PulseAudio.
* Fix ALSA digital pass-through ("S/PDIF").
* Fix live audio device selection on Mac OS X
* Fix detection of some 5.1 and 7.1 kits on Windows.
* Fix audio output behavior when the output device is plugged or unplugged
during playback on Mac OS X
Access:
* Fix numerous DVD (dvdnav) crashes
* Fix HTTP playback through proxy and advertise gzip correctly
* Fix TLS busy-loop during client-side handshake
Codecs:
* Support for Opus decoding via libopus, including multi-channel files
* Support MSS1 and MSS2 decoding through DMO libraries
* Fix Hebrew and Greek subtitles encoding
* Fix crashes on malformed subtitles and malformed png files
* Fix crashes when using hardware decoding
Demuxers:
* Fix issues in Ogg with zero length packets
* Fix file duration of Ogg/Theora and Ogg/Vorbis files
* Fix vimeo, koreus and youtube lua parsers
* Support Youtube live streams
Windows:
* Fix Wallpaper mode on Windows 7/8
Qt:
* Fix media info dialog update
* Fix random/repeat preferences saving
* Fix crashes when opening audio effects dialog, with skins and playlist
* Fix crash on association dialog on Windows XP
* Fix album art display at start
Mac OS X:
* Fix command-line options to control the interface behavior
* Deactivate CoreAnimation effects on Leopard
* Fix menus display and behavior
* Fix various crashes and small issues including bookmarks, playlist, buttons,
streaming wizard, video size, hotkeys and fullscreen controller
* Fix font selection for Unicode subtitles
* Improve system sleep behavior when playing audio-only media. The screen is
allowed to sleep while the system is kept awake during playback.
* Fix code signing of Delete Preferences application
* Add option to Audio Effects panel to activate the Karaoke filter
Miscellaneous:
* Fix Notify (D-Bus) plugin deadlock.
* Fix buffer corruption in freetype and subtitles modules
* Improve Blu-Ray and HLS support
* Fix issues on selection of playlist items for WebUI
* Codec and other 3rd party library updates
* Fix swscale and canvas behavior with Aspect Ratio
* Fix mime-type when streaming Webm over HTTP
* Fix recording behaviour in Windows network environments
* Codecs and 3rd party libary updates
Translations:
* Updates of Norwegian Bokmål, Korean, Slovak, Serbian, Russian, Traditional
Chinese, Simplified Chinese, Portuguese, Walloon, Turkish, Thai, Polish,
Dutch, Khmer, Hindi, Japanese, Galician, Hebrew, German, Breton, Scottish
Gaelic, Czech, Estonian translations
* Initial translations for Bengali, Fula, Gujarati and Bosnian
Info&download
