Winamp 5.9 (09/09/22)
Winamp 5.52
Info&download qui
* Improved: Better Unicode filename support for enc_*.dll audio encoders
* Improved: [ml_transcode] Unicode filename support
* Improved: [in_mp3] APEv2 tag support
* Improved: [in_flac] Support for reading/writing BPM metadata
* Improved: [nde] Optimized for faster mldb query results
* Improved: [vis_milk2] Pixel shaders now work on onboard Intel graphics chips
* Fixed: Comment field character limitation in Basic Info tab of File Editor
* Fixed: Playback Thread Priority middle setting resets to Lowest
* Fixed: [in_mp3] Ultravox streaming metadata stack overflow
* Fixed: [in_mp4] Crash when attempting to play non-existent files
* Fixed: [in_vorbis] Crash when clearing existing metadata fields in File Info
* Fixed: [in_wave] Transcoding of floating point WAV files
* Fixed: [ml_transcode] Memory leaks
* Misc: More miscellaneous general tweaks and improvements
* Updated: Bento skin #118
Rilasciato Winamp 5.54
Info&download qui
* New: Chinese, Japanese & Korean installer translations and language packs
* New: [in_swf] Adobe Shockwave Flash (SWF, RTMP) playback support
* New: [gen_dropbox] Winamp DropBox alpha (use: Ctrl-Shift-D)
* New: [Online Services] AOL Radio featuring CBS Radio (requires in_flv)
* Improved: Background reading option for playlist metadata
* Improved: Classic songticker scrolling for Winamp Modern skin pledit winshade
* Improved: Vista elevation (fixes: installing skins, filetype reg, Pro reg)
* Improved: Zero padding option for playlist item numbers
* Improved: [in_flv] Better streaming support and other improvements
* Improved: [in_mp3] Added APEv2 tag options to configuration
* Improved: [in_mp3] Optional retention of existing APEv2 headers
* Improved: [ml_disc] Artwork support for Data CD Reader
* Improved: [ml_disc] Better detection of any copy operations in progress
* Improved: [ml_disc] Improved start times if ml_disc view is active
* Improved: [ml_local] Redesigned 'Show Info' panel
* Improved: [ml_nowplaying] Redesigned 'Now Playing' artist experience
* Improved: [ml_playlists] Right-click option to sort list of playlists alphabetically
* Improved: [pmp_usb] Connect/Disconnect/Blacklist config options
* Fixed: Alt+F4 closing Winamp instead of individual dialogs
* Fixed: Bento browser redirecting network drive url's to Winamp Search
* Fixed: Blank playlist when in docked toolbar mode and Winamp is minimized
* Fixed: Modern skin component windows appearing individually in Alt+Tab
* Fixed: Multi-flashing on startup when previously closed whilst minimized to systray
* Fixed: Pure Virtual Function Call runtime crash errors
* Fixed: Redraw issue when built-in classic vis is disabled
* Fixed: Various multi-monitor docking issues
* Fixed: Various other 5.53-specific keyboard accelerator issues
* Fixed: [Bento] Drag+Drop into Playlist from Open Files dialog
* Fixed: [burnlib] 'CD Drive locked by another Winamp process' on 2nd burn attempt
* Fixed: [burnlib] 'Burner releasing failed' error
* Fixed: [dsp_sps] Crash on close when config Help dialog is still open
* Fixed: [enc_flac] MD5 checksum generation
* Fixed: [gen_ff] Attached vis plugin crash on winshade to normal mode in Modern skin
* Fixed: [gen_hotkeys] Assigning Winkey with already used Ctrl combinations
* Fixed: [gen_ml] Enter/Shift+Enter broken for ML treeview items (5.53-specific)
* Fixed: [in_cdda] Composer/Conductor logic bug when saving CDDB data to database
* Fixed: [in_flac] Minor metadata writing bugs
* Fixed: [in_midi] Seeking with 'DM/MS Synth' device in Streamed playback mode
* Fixed: [in_mp3] Crash on files with invalid/corrupt gapless data
* Fixed: [in_mp3] Create new ID3v1/v2 tags configuration setting
* Fixed: [in_vorbis] Huge lag on files with large embedded cover art
* Fixed: [in_vorbis] Metadata & Format Info display for streams in View File Info
* Fixed: [in_vorbis] Potential unicode-related crash on open/close issue
* Fixed: [jpeg.w5s] Saving corrupt album art
* Fixed: [ml_autotag] Results dialog hidden under Winamp when AOT is enabled
* Fixed: [ml_disc] Small resource leak
* Fixed: [ml_playlists] Enter/Shift+Enter broken for selected ML Playlist items
* Fixed: [ml_playlists / ml_transcode] Sending playlists from ML tree to Transcoder
* Fixed: [ml_wire] 404/timeout with valid rss feeds on Vista
* Misc: Miscellaneous localization tweaks, fixes & updates
* Misc: More miscellaneous general tweaks, improvements, fixes and optimizations
* Misc: Setup fixes (Agent not always starting, WLZ filetype not registering, etc)
* Misc: Various other 'Winamp Modern' & 'Bento' skin updates
* Misc: [enc_flac] Now encodes using libFLAC instead of Flake
* Updated: Bento skin v1.2
* Updated: freetype 2.3.7
* Updated: libpng 1.2.28
* Updated: [enc_lame] LAME 3.98
Riporto su questo vecchio thread...:D
In arrivo nei prossimi giorni Winamp 5.8 (con correzioni e bugfix)... la prima release dopo il cambio di proprietà. Atteso invece per il 2019 il nuovo Winamp 6 (integrato anche con i vari servizi cloud e streaming).
Da appassionato di audio ho abbandonato winamp da 15 anni. Meglio foobar2000.
Quindi sta resuscitando dopo moltissimi anni WinAmp, questa si che è una bella notizia, come lettore player ricordo che non era male, lo usavo tantisismi anni fa. :)
Ok grazie Ber, lo scarico e lo installo subito vediamo con i nuovi sistemi operativi tipo Windows 10 Pro a 64 Bit come va. :icon_rolleyes:
Winamp 5.9
Rilasciato Winamp 5.9 RC1 Build 9999
non ancora versione stabile...
Codice:
Winamp 5.9
* Improved: Windows 11 compatibility
* Improved: Playback of https:// streams
* Improved: Updated and tidier generate html playlist code
* Improved: [in_mkv] vp8 support
* Improved: [in_mod] Playback of .itz, .mdz, .s3z & .xmz compressed modules
* Improved: [ml_wire] New working Podcast Directory
* Improved: [out_ds] Display device information correctly in Unicode format
* Fixed: [in_midi/in_mkv/nu/pfc] memory leaks
* Fixed: [in_mp3] id3 empty genre displayed as Blues or Psychobilly
* Fixed: [jnetlib/ml_online/ml_wire] JSAPI2 JavaScript API
* Misc: lame_enc & libsndfile now static links instead of dynamic dll
* Misc: libmpg123, libflac & zlib now static links instead of dynamic dll
* Misc: libalac.dll added to Shared folder as part of alac update
* Misc: Major compiler refactoring work
* Misc: Many more general tweaks, improvements, fixes and optimizations
* Misc: Minimum required OS is now Windows 7 SP1
* Misc: New online Help section and articles
* Misc: SDK now compatible with VS2017 and newer
* Misc: Versioning syntax changed to v5.x.x
* Misc: Winamp\Microsoft.VC142.CRT runtimes now installed on Win7/8
* Removed: Bento Browser tab - So long, and thanks for all the fish!
* Updated: [alac/in_mp4] ALAC 2017-11-03-c38887c5
* Updated: [enc_lame] LAME 3.100.1
* Updated: [freetype.wac] freetype 2.12.1
* Updated: [gif] giflib 5.1.4
* Updated: [in_cdda] libdiscid 0.6.2
* Updated: [in_flac/enc_flac] libFLAC 1.3.4
* Updated: [in_mod] libopenmpt 0.7.0 & Portaudio 19.7.0
* Updated: [in_mp3] libmpg123 1.29.3
* Updated: [in_vorbis] libogg 1.3.5 & libvorbis 1.3.7
* Updated: [in_wave] libsndfile 1.1.0
* Updated: [OpenSSL] OpenSSL 3.0.3
* Updated: [png] libpng 1.6.37
* Updated: [vp8] WebM libvpx 1.11.0
* Updated: [zlib] zlib 1.2.12
Scaricata ed installata questa nuova versione finale di Winamp 5.9 Build 9999, richiede in sede di preinstallazione le librerie di Microsoft Visual C++ 2015-2019 ;)
