aggiornata la versione su xp ma se lancio un video, lo stesso, rispetto alla versione precedente, non parte ma compare solo la finestra degli strumenti
nel frattempo ho rimesso la versione precedente ed il video, una volta selezionato, parte automaticamente;
qual'è il problema?
Changes between 3.0.0 and 3.0.1:
Core:
* Fix use-after-free when cleaning playlists
* Fix crash on exit on Windows
Video output:
* Fix HLG tone mapping on some systems like macOS.
* Fix screensaver inhibition on Windows XP
* Fix various Direct3D11 crashes
* Fix HDR tone mapping in Direct3d11
* Fix pink screen on Windows
Decoder:
* Fix potential stack buffer overflow with faad
* Enable Cineform HD in avcodec
Hardware Decoder:
* macOS: Improve HEVC 10bit performance with Videotoolbox
* android: Add MPEG2 support via MediaCodec
* Fix HEVC decoding with some files on Android/macOS/iOS
* Improve Direct3D11 memory usage
Demux:
* Improve MKV seeking speed
* Fix xspf base URL handling
* Fix reading mp4 trun with moof based offsets
* Fix adaptive http redirections
* Replace old API, fixing adaptive TLS leak
* Use mime type as fallback for HLS segment type
* Fix subtitle (srt,ssa..) seek when having a single entry
* Flag non default HDMV subset video streams
* Increase TS probing amount for 4K streams
* Miscellaneous MKV, MP4 & AVI crash fixes
Packetizer:
* Fix out of bounds read in mpeg4video
Stream Output:
* Improve chromecast loading speed
* Improve local/chromecast transition during playback
* Fix chromecast loading with some versions of Windows
* Fix chromecast loading with some chromecast devices (TVs and Android boxes)
* Fix wrong first cover art when casting
* Fix casting to VP9
macOS Interface:
* Re-add option to disable the fullscreen controller panel
* Auto-layout improvements
* Remove misleading playback warning indicator
* Fix crash with the interface for lua extensions (like VLSub)
* Fix show sidebar setting being ignored on restart
* Fix MKV files association
* Fix chromecast audio detection
Qt Interface:
* Improve scaling on HiDPI displays
Snap:
* Improve interface look and feel.
Ok, vediamo se nelle versioni successive sistemano, in quanto in determinate situazioni, soprattutto se registro, mi torna utile sapere il timing.
Perfetto, in serata aggiornoRisolto con la versione 3.0.1
Perfetto, in serata aggiorno![]()
Aggiornato, tornato tutto regolarePerfetto, in serata aggiorno![]()
Scarica manualmente![]()
Si vero, notato pure io...a dire il vero lo noto da un bel po'.Scaricato manualmente, tutto ok, unica cosa non riesco a riprodurre i video di youtube in HD. Si bloccano di continuo, mentrese li riproduco da youtube stesso nessun poblema.
Intendi Apri flusso di rete... ?Scaricato manualmente, tutto ok, unica cosa non riesco a riprodurre i video di youtube in HD. Si bloccano di continuo, mentrese li riproduco da youtube stesso nessun poblema.
Changes between 3.0.1 and 3.0.2:
Core:
* Fix snapshotting with subtitles when using hardware acceleration
* Fix green/missing line/column when the picture dimensions are odd
Decoders:
* Important improvements in hardware decoding for macOS, notably faster,
supporting more samples and removing crashes/deadlocks
* Improve compatibility for DxVA2 and D3D11 decoding, fix crashes when seeking
and fix blacklisting of broken drivers
* Fix SSA subtitles forced alignment
* Fix E-AC-3 stuttering
* Fix MIDI playback on macOS
* Add playback support for ProRes 4444 XQ
Demux:
* Fix wrong colors in some AVI files
* Fix IFO files playback to start DVDs
* Fix a crash with missing/invalid MPEG SDT
* Update VP8/9/10 ISOBMFF bindings and improve HDR for those cases
* Fix TTML inside MP4
* Improve MP4 read of color information
* Fix flac seeking and improve flac parsing
* Improve mkv opening & seeking speed
* Fix display of chapters with no name defined
* Miscellaneous MKV crash fixes
* Fix crash with multi-region DVDs
* Fix audio being muted on DVD chapter change
* Fix audio being muted when seeking in a BluRay disc
Access:
* Avoid a crash/assert in FTP after seeking
Audio output:
* Fix mmdevice default audio device handling
* Fix "reset audio volume" being forcefully deactivated
* Allow a default device to be used by VLC
* Only warn once about misconfiguration for AUhal devices on macOS
* Improve resampling and latency computation for CoreAudio
* Passthrough is now disabled by default
Audio filters:
* Fix audio stutter after unpausing with headphones
* Fix silence when dolby-surround was mis-selected in preferences
Video output:
* Fix OpenGL crashes or bad display with semi-planar chromas
* Fix OpenGL interop (zero-copy) disabled for tvOS
* Major rewrite of the iOS video output to fix numerous crashes
* Important improvements of the D3D11 video output to use less memory
and less GPU for HDR tone-mapping
* Fix crop on vertical videos with Direct3D11
* Fix Direct3D9 filters settings not being applied properly
* Fix transform filters with hardware decoding
* Fix snapshot and filters with HEVC hardware decoding
* Fix a buffer overrun during GPU/CPU image copy
* Fix glitches on DVD menus with Direct3D11
* Fix non-HDR content playback on HDR screens with Direct3D11
* Fix YUV full range displayed incorrectly in Direct3D11
* Fix miscellaneous crashes in Direct3D11
* Fix potential black screen with 10bits videos on Direct3D11
macOS:
* Fix Growl notifications on recent macOS versions
* Fix conversion output file name encoding
* Fix crash reporting on macOS 10.7 and 10.8
* Fix crash on exit
* Fix remember playback position
* Fix Blu-ray disc Java menu
* Fix swiping on time slider to change position
* Fix problems with restoring user name from keychain
* Fix localization issues
Qt:
* Fix last folder used in open dialogs
* Allow to customize the seek jump when using the mousewheel
* Fix fullscreen controller positionment on multiscreen setups
* Fix pasted URLs not being trimmed
* Fix jump size not being configurable
* Fix missing time labels updates
* Fix playback speed slider not accepting 1.0x value
* Fix raw input dump
* Fix window size after a fullscreen playback
Misc:
* Fix lua rc & oldrc interfaces host specification
* Fix crashes when searching for renderers
* Relocate localedir for Linux (improves snap i18n support)
* Fix VDPAU GLX usage on Linux
* Improve support for NetBSD
* Fix MSI script for Windows
* Fix libvlc_media_list not going to next media
* Fix character encoding on win32 consoles
* Miscellaneous chromecast improvements
* Fix missing OSD navigation feedback
* Various VLSub improvements
* lua: Fix scripts not being loaded on some filesystems
* lua: Add vlc.io APIs to handle UTF-8 paths
