17.05.2006 version 2.5.0.82
* feature: SMS button added in profile for SkypeOut contacts
* feature: extra Warning dialog displayed when executable file is opened
* change: "Send SMS" hint should only be visible if mobile number is entered
* change: if signed out, menu Help > ‘Check for updates’ will go to download webpage
* change: SMS icon changed to service icon
* change: 'advanced' button made wider in authorization form
* change: updated EULAs
* change: updated language files
* change: SMS window was missing my mood message
* change: SMS window title should contain the telephone number or Skype name of the recipients
* change: SMS authorization options design changed
* change: uninformative error message when adding too many participants to SMS
* change: AltGr + W closed SMS composition window
* change: only focused emoticon animates in SMS windows
* change: OK button changed to Accept in File Transfer window
* change: button name was wrong in dialog when reseting back the original Voicemail greeting
* bugfix: keyboard '#' character did not make the equivalent DTMF tones
* bugfix: DTMF-s from dial pad did not work
* bugfix: text missing in search window if Korean language is chosen
* bugfix: "send chat message" button in Multi Chat button hidden in 16bit color mode
* bugfix: number auto formatting incorrect when entered from history tab
* bugfix: 'outlook contacts' group missing when clicking View Outlook Contacts
* bugfix: was possible to get 'List Index out of bounds' error messages when using Shared Groups
* bugfix: Chinese EULA was shown in installer when Czech language was used
* bugfix: Estonian and Greek EULA missing from installer
* bugfix: API: Accepting or declining Shared Group via API leaves invitation form open
* bugfix: Portugal Portuguese, Czech, Hungarian, Polish, Bulgarian languages were missing from installer
* bugfix: Estonian, Netherlands, Greek, Portuguese Portugal EULA were missing in installer
* bugfix: remove SkypeOut warning for free PSTN calls
* bugfix: calling users when you ae in offline mode now disabled
* bugfix: when pressing Add Contact - 'Add' form is pre-filled with the user name in focus
* bugfix: was not possible tp enter @ sign via Alt-Gr in to Payments in Client field
* bugfix: Skype crashed on incoming PSTN call when number was not shown
* bugfix: gray text in address bar changes when tab is changed from contacts tab to history tab
* bugfix: icon on call tab looked bad on Windows 98 and Millennium Edition
* bugfix: icons on File Transfer window looked bad on Windows 98 and Millennium Edition
* bugfix: "Delete This Entry" was missing trash bin graphics
* bugfix: unknown numbers missed "Delete This Entry" context item
* bugfix: cost and balance in JPY shown wrong in SMS windows
* bugfix: log area popup menu is back in SMS windows
* bugfix: 'remove from this group' option should be grayed out
* bugfix: "this person has left the group" appeared on top of numbers
* bugfix: there was no confirmation dialog when renaming a Shared Group
* bugfix: Call Tab closed when calling a not existing Skype name
Info&download qui
Info&download qui
