Discussione su AdwCleaner
nuova versione => 7.0.8.0
--Changes--
Update MyWebSearch generics
Update Multiplug generics
Update WebCompanion generics
Update WinYahoo generics
Update DealPly generics
Update folders generics
Update Italian translation
Backport v7.1 internal naming
Database 2018.02.08.1
Nuova versione => 7.1.0.0
a) New Features
Brand new user interface, with high-DPI support, accessibility improvement
Add a dedicated Help section with various resources to get assistance and contribute.
Support for synchronized addons in Chrome, and include massive improvements in browsers scan and clean efficiency.
Display a scan summary at reboot.
Exclusions Support for elements and families to be excluded from the detections.
b) Changes
Major improvements in scan and remediation speed.
Reduce binary size.
Improve the reliability of the update process
Improve translations coverage.
Settings format is more effective and less error prone.
Improved report design for better usability
Redesign*https://www.malwarebytes.com/adwcleaner/
Update definitions to 2018.04.11.1
Component updates
c) Bugfixes
Quarantine process and restoration work again.
Fix numerous generic detection issues and design flaws.
Fix various crashs and miscellaneous issues.
Ad ogni modo fino a che non clicchi fix non hai comunque il riavvio immediato, quindi non vedrei dove sia il problema.
Tutto bello e forse qualche nuova funzione e opzione (anche se io ho lasciato tutto come di default) però ci sono anche forme di pubblicità a favore dei programmi più completi e a pagamento di Malwarebytes, niente di troppo eccessivo e fastidioso comunque, e fa sempre il suo buon lavoro.
nuova versione => 7.1.1
a) New Features
Exclusions now support processes
New setting to fully disable the telemetry
Support keyboard navigation with tabs
b) Changes
Add a "See logfile" button on scan results screen
Scan shortcuts, files and folders in more locations
Improve tasks detection
Definitions 2018.04.24.1
c) Bugfixes
Various UI issues
Update translations
Fix false positives
Improve generics for drivers
https://toolslib.net/downloads/viewdownload/1-adwcleaner/history/
