[fonte: sito "smallnetbuilder"]That makes me wonder if a 500Mbit adapter of brand A will be better than brand B. Will a Netgear do better than a Zyxel or vice-versa?
In the real world there's no right answer. Everyone's wiring is different. I tried a pair of the netgear adapters and couldn't get higher than 30 megabits of consistent bandwidth in a certain location of my home. However, with a pair of the zyxel's in the same location I get consistent bandwidth of 60 megabits which is just enough for bluray streaming.
[fonte: sito di supporto "custhelp" della WD]While the WD TV Live Line of products (WD TV Live Hub Media Center, WD TV Live Streaming Media Player, WD TV Live Plus HD Media Player, and WD TV Live (WDBAAx0000NBK) HD Media Player) do not officially support 3D videos, some of our users have reported being able to play some 3D content using their device. For more information about playing 3D movies using a WD TV Live product, please see the information below:
WD TV Live products can play many 3D videos that are encoded with the side-by-side (left & right) format.
A 3D ready TV is required to play side-by-side 3D videos.
WD TV Live products are not capable of playing frame sequential 3D videos or newer 3D formats defined by BluRay
[fonte: forum di supporto "Community" della WD]I have the 2nd gen of WD TV Live and it works fine for me, except the bitstream of the HD audio. I have lots of MKVs with HD audio included, Live can bitstream the Dolby TrueHD but can't do DTS-HDMA, only DTS core is bit streamed. And WD states it is because of the license restriction
The reason that the SMP/HUB can't pass-through DTS-HD is because they are under the DTS license, but not not DTS-HD license. So the reason that WD can't implement DTS-HD pass-through, even through it doesn't require a license to do so, is because if they did it would affect the DTS license. Meaning if WD implemented DTS-HD pass-through, they would lose their DTS licensing. The only way to have both (DTS & DTS-HD) is to be licensed for both, and without the DTS licensing the SMP/HUB could not downmix which would affect people who don't have a AVR or other device that could decode those audio types.
[fonte: Wikipedia]DTS-HD Master Audio is a lossless audio codec created by Digital Theater System ... DTS-HD Master Audio is an optional audio format for Blu-ray Disc format, but has steadily become the standard for Blu-ray lossless audio format.
Salve a tutti, mi affaccio anch'io su questo forum dopo essere passato (sempre su digital-forum.it) su quello relativo all'Humax Digimax (a proposito, Acetone: ho appena stampato le etichette per la restituzione, domani passa il corriere e lo ritira).
In sostanza, non credo di avere le necessità espresse in qualche contributo dei precedenti messaggi ... il Media Player che mi serve ( e di cui chiedo consiglio), sostanzialmente deve evere queste caratteristiche:
- collegarsi la NAS Fujitsu Q700 senza necessariamente usare sw dlna (tipo il Twonky) che mi sembra limitato e gestire i files multimediali del NAS da interfaccia e sw interno al lettore;
- essere autofps o perlomeno, consentire (come mi sembra di capire) di allineare i parametri del flusso video tale da non vedersi a scatti. Meglio se lo consente anche con l'audio....
- non credo di passare al TV 3D prima di una settecentocinquantina d'anni ... scherzi a parte, adesso non me lo posso permettere. QUello che ho deve durare ... finchè dura! E perciò posso rinunciare all'hdmi 1.4 e altre caratteristiche specifiche di quella tecnologia;
- vorrei vedere le fotografie .. almeno come le vedo da penna usb collegata al TV! L'Humax sottoponeva, in basso allo schermo (sotto il menu osd -avanti, indietro- ecc), una velata di nero sfumato anche disattivando il menu osd.. e perciò le foto erano vignettate verso il basso. Inoltre, le immagini erano di scarsa qualità ... seghettate ... brutte!
- se potessi vedere (come sembra da agg. firmware) qualcosa tipo jukeboxe, con cover, durata ecc del film. Ma non è essenziale.
- budget: ne avevo spesi 172 per l'Humax.... al massimo la stessa cifra ..... se meno meglio, perchè potrei farci rientrare un (modesto) dvb-tuner su cui (ogni tanto) registrare qualcosa.
Scusate eventuali imprecisioni tecniche ....
p.s.: se qualcuno volesse passarmi via privata cosa hanno per fare qullo che sto chiedendo (se qui non fosse possibile), sarebbe veramente gradito
Briccardo
