Velocità scrittura HDD SSD
  • Creatore Discussione Creatore Discussione Tuco
Tuco
Digital-Forum Master
24 Agosto 2017
Arezzo
Appena preso oggi un HDD SSD da 128 GB
Drive Model: Intenso SSD Sata III
' su un controller SATA III 6GB
E' lentissimo in scrittura, come mai?
Codice:
Intenso  SSD Sata III -----------------------------------------------------
 [General Information]
  Drive Controller:                       Serial ATA 6Gb/s @ 6Gb/s
  Drive Firmware Revision:                Q0303B
  Drive Serial Number:                    AA0000000000000118+++
  World Wide Name:                        5000000
  Drive Capacity:                         120,832 MBytes (126 GB)
  Drive Capacity [MB]:                    120832
  Media Rotation Rate:                    SSD Drive (Non-rotating)
  ATA Major Version Supported:            ATA/ATAPI-5, ATA/ATAPI-6,
ATA/ATAPI-7, ATA8-ACS, ACS-2
  ATA Transport Version Supported:        SATA 3.1
 [Drive Geometry]
  Number of Cylinders:                    16383
  Number of Heads:                        16
  Sectors Per Track:                      63
  Number of Sectors:                      16514064
  Total 32-bit LBA Sectors:               247463936
  Total 48-bit LBA Sectors:               247463936
  Logical Sector Size:                    512 Bytes
  Cache Buffer Size:                      N/A
 [Transfer Modes]
  Sectors Per Interrupt:                  Total: 2, Active: 2
  Max. PIO Transfer Mode:                 4
  Multiword DMA Mode:                     Total: 2, Active: -
  Singleword DMA Mode:                    Total: -, Active: -
  Ultra-DMA Mode:                         Total: 6 (ATA-133), Active: 5
(ATA-100)
  Max. Multiword DMA Transfer Rate:       16.7 MBytes/s
  Max. PIO with IORDY Transfer Rate:      16.7 MBytes/s
  Max. PIO w/o IORDY Transfer Rate:       16.7 MBytes/s
  Native Command Queuing:                 Supported, Max. Depth: 32
  TRIM Command:                           Supported (Deterministic Read
After TRIM, Words = 0)
 [Device flags]
  Fixed Drive:                            Present
  Removable Drive:                        Not Present
  Magnetic Storage:                       Present
  LBA Mode:                               Supported
  DMA Mode:                               Supported
  IORDY:                                  Supported
  IORDY Disableable:                      Supported
 [Features]
  Write Cache:                            Present, Active
  S.M.A.R.T. Feature:                     Present, Active
  Security Feature:                       Present, Inactive
  Removable Media Feature:                Not Present, Disabled
  Power Management:                       Present, Active
  Advanced Power Management:              Not Present, Inactive
  Packet Interface:                       Not Present, Disabled
  Look-Ahead Buffer:                      Present, Active
  Host Protected Area:                    Present, Enabled
  Power-Up In Standby:                    Not Suppported, Inactive
  Automatic Acoustic Management:          Supported, Inactive
  48-bit LBA:                             Supported, Active
  Host-Initiated Link Power Management:   Supported
  Device-Initiated Link Power Management: Supported, Disabled
  In-Order Data Delivery:                 Not Supported
  Hardware Feature Control:               Not Supported
  Software Settings Preservation:         Supported, Enabled
  NCQ Autosense:                          Not Supported
  Link Power State Device Sleep:          Supported, Disabled
  Hybrid Information Feature:             Not Supported
  Rebuild Assist:                         Not Supported
  Power Disable:                          Not Supported
  All Write Cache Non-Volatile:           Not Supported
  Extended Number of User Addressable Sectors: Not Supported
  CFast Specification:                    Not Supported
  NCQ Priority Information:               Not Supported
  Host Automatic Partial to Slumber Transitions: Not Supported
  Device Automatic Partial to Slumber Transitions: Not Supported
  NCQ Streaming:                          Not Supported
  NCQ Queue Management Command:           Not Supported
  DevSleep to Reduced Power State:        Supported
  Extended Power Conditions Feature:      Not Supported
  Sense Data Reporting Feature:           Not Supported
  Free-Fall Control Feature:              Not Supported
  Write-Read-Verify Feature:              Not Supported
 [Security]
  Security Feature:                       Supported
  Security Status:                        Disabled
  Security Locked:                        Disabled
  Security Frozen:                        Enabled
  Enhanced Security Erase:                Supported
  Sanitize Feature:                       Supported
  Sanitize Device - Crypto Scramble:      Not Supported
  Sanitize Device - Overwrite:            Not Supported
  Sanitize Device - Block Erase:          Supported
  Sanitize Device - Antifreeze Lock:      Not Supported
  Device Encrypts All User Data:          Not Supported
  Trusted Computing:                      Not Supported
 [Self-Monitoring, Analysis and Reporting Technology (S.M.A.R.T.)]
  [01] Raw Read Error Rate:               100/Always OK, Worst: 100
  [05] Reallocated Sector Count:          100/Always OK, Worst: 100
  [09] Power-On Hours/Cycle Count:        100/Always OK, Worst: 100 (1
hours)
  [0C] Power Cycle Count:                 100/Always OK, Worst: 100 (Data =
7,0)
  [A0] Uncorrectable Sector Count:        100/Always OK, Worst: 100
  [A1] Valid Spare Blocks:                100/Always OK, Worst: 100 (Data =
92,0)
  [A3] Unknown                            100/Always OK, Worst: 100 (Data =
107,0)
  [A4] Unknown                            100/Always OK, Worst: 100 (Data =
1515,0)
  [A5] Maximum TLC Erase Count:           100/Always OK, Worst: 100 (Data =
2,0)
  [A6] Minimum TLC Erase Count:           100/Always OK, Worst: 100
  [A7] Average TLC Erase Count:           100/Always OK, Worst: 100
  [A8] SATA PHY Error Count:              100/Always OK, Worst: 100 (Data =
3000,0)
  [A9] Percentage Lifetime Remaining:     100/Always OK, Worst: 100 (Data =
100,0)
  [AF] Program/ECC Fail Count:            100/Always OK, Worst: 100
  [B0] Erase Fail Count:                  100/Always OK, Worst: 100
  [B1] Wear Leveling Count:               100/50, Worst: 100
  [B2] Used Reserved Block Count (Chip):  100/Always OK, Worst: 100
  [B5] Program Fail Count (Total):        100/Always OK, Worst: 100
  [B6] Erase Fail Count (Total):          100/Always OK, Worst: 100
  [C0] Power-off Retract Count:           100/Always OK, Worst: 100 (Data =
2,0)
  [C2] Temperature                        100/Always OK, Worst: 100 (31.0
°C)
  [C3] ECC Error Rate:                    100/Always OK, Worst: 100
  [C4] Reallocation Event Count:          100/16, Worst: 100
  [C5] Current Pending Sector Count:      100/Always OK, Worst: 100
  [C6] Off-Line Uncorrectable Sector Count: 100/Always OK, Worst: 100
  [C7] SATA CRC Error Count:              100/50, Worst: 100
  [E8] Available Reserved Space:          100/Always OK, Worst: 100 (Data =
100,0)
  [F1] Total Host Writes:                 100/Always OK, Worst: 100 (Data =
1877,0)
  [F2] Total Host Reads:                  100/Always OK, Worst: 100 (Data =
2325,0)
  [F5] Total TLC Write Count:             100/Always OK, Worst: 100 (Data =
3030,0)
  Drive Remaining Life                    100%
 [Device Statistics]
  Lifetime Power-On Resets:               7
  Power-on Hours:                         1
  Logical Sectors Written:                123069510
  Logical Sectors Read:                   152432589
  Number of Write Commands:               1302723
  Number of Read Commands:                1590742
  Number of Reported Uncorrectable Errors: 0
  Resets Between Command Acceptance and Completion: 2
  Number of Hardware Resets:              27
  Number of Interface CRC Errors:         0
  Used Endurance Indicator:               0%
C:\Windows\system32>fsutil behavior query DisableDeleteNotify
NTFS DisableDeleteNotify = 0 (Disabilitato)
ReFS DisableDeleteNotify = 0 (Disabilitato)
Verifica anche che i settori del SSD sono allineati...
Apri system information (in cerca scrivi system information, oppure vai in Accessori --> Utilità di sistema). Poi in system information vai in Componenti --> Archiviazione --> Dischi, trova il disco SSD e cerca la stringa "Offset avvio partizione", poi dividi il numero dei byte visualizzati per 4096.. se esce un numero intero, allora SSD è allineato.
Esempio nel mio visualizza 1.048.576 byte, quindi 1.048.576:4096=256. 256 essendo numero intero, significa che il valore dell'offset di avvio partizione è divisibile per 4096, quindi l'SSD è allineato...
E' allineato...
Edit: credo che la tua versione è quella top e non la high (che ha prestazioni in scrittura quasi pari a quella in lettura)..
La Top idealmente può raggiungere in scrittura sequenziale i 300 MB/s (76.800 IOPS) e in lettura 520 MB/s (133.120 IOPS).
Mentre la High fino a 500 MB/s (128.000 IOPS) in scrittura e 520 MB/s (133.120 IOPS) in scrittura.
Verifica da BIOS se la modalità AHCI è abilitata (supporto sata nativo), altrimenti il trim non può funzionare.
E' allineato...
ma se a malapena arriva a 150mb in scrittura?!
Sarà un modello farlocco, come detto prima sul portatile ho un verbatin da 128GB va a 450 circa lettura e scrittura.
E' attivo come ho già detto sopra.
Sarà anche un modello farlocco, ma da quel SSD non ti aspettare grandi prestazioni... quei 300 MB/s sono puramente ideali, non ci arriverà mai. Al limite può arrivare sui 260~270 MB/s, ma non di più.
