News about this release:
[FONT="]New Skin lite selectable on advanced menù[/FONT]
[FONT="]Osd Info fixed selectable on advanced menù[/FONT]
[FONT="]Hard disk management fixed[/FONT]
[FONT="]Ctdyn fixed (now show log on ctdyn menu panel)[/FONT]
[FONT="]Move Var plugin hdd/usb/hdd[/FONT]
[FONT="]Support for multiboot (Ipbox250/350 with flashwizard version for ipbox)[/FONT]
[FONT="]New Kernel module fdisk [/FONT]
[FONT="]New libc.so.6 (now newcs works good)[/FONT]
[FONT="]Vpn module Fixed for ipbox (download new vpn complete module from blue panel )[/FONT]
[FONT="]Mmc driver module inserted (for ipbox,Thanks to Sandali)[/FONT]
[FONT="]Minor bug fixed[/FONT]
[FONT="]Many thanks to: [/FONT]
[FONT="] Ngc1927-Porto-GeNgE-Frog68-Sandali-Astemio-Voodo3-Lorenzo64-Neri-Black§kettle-Maxz4-Jlmota-Adamo49-U_Killer_Bestia
[/FONT]
[FONT="]IPBOX200S:[/FONT]
[FONT="]-------------[/FONT]
[FONT="]Usable to flash[/FONT]
[FONT="]* Enigma of: 11.11.2007 (patched for native version)[/FONT]
[FONT="]* Linux version 2.6.17 (patched from sandali)[/FONT]
[FONT="]* Web Interface: 6.0.2-Expert[/FONT]
[FONT="]* Busybox 1.01[/FONT]
[FONT="]* U-BOOT 1.2.0 (patched from sandali)[/FONT]
[FONT="]* New driver from sandali[/FONT]
[FONT="]* Auto SET mID[/FONT]
[FONT="]IPBOX250S:[/FONT]
[FONT="]---------[/FONT]
[FONT="]Usable to HDD (CF) or flash[/FONT]
[FONT="]* Tuxtxt v. 1.99[/FONT]
[FONT="]* SET mID for cubecafe (25)- If you want use multiboot use mid dm700[/FONT]
[FONT="]IPBOX350S:[/FONT]
[FONT="]Usable to HDD (CF), USB or flash[/FONT]
[FONT="]* SET mID for cubecafe prime (26)- If you want use multiboot use mid dm700[/FONT]
[FONT="]DB500:[/FONT]
[FONT="]--------[/FONT]
[FONT="]* Enigma of: 11.11.2007[/FONT]
[FONT="]* Linux version 2.6.9[/FONT]
[FONT="]* GCC 3.4.4 Original CVS[/FONT]
[FONT="]DB5620:[/FONT]
[FONT="]DB7000:[/FONT]
[FONT="]Usable to HDD, USB, CF or flash[/FONT]
[FONT="]* GCC 3.4.4 Original CVS 1.1.0[/FONT]
[FONT="]DB7020:[/FONT]
[FONT="]* Usable to HDD, USB, CF or flash[/FONT]
[FONT="]* OE Build Configuration:[/FONT]
[FONT="]BB_VERSION = "1.6.2"[/FONT]
[FONT="]OE_REVISION = "format_version "1"[/FONT]
[FONT="]OE Build Configuration:[/FONT]
[FONT="]new_manifest [0000000000000000000000000000000000000004][/FONT]
[FONT="]old_revision [8f1ea263b352bd617459b584cd2b61bd42550b29]"[/FONT]
[FONT="]TARGET_ARCH = "powerpc"[/FONT]
[FONT="]TARGET_OS = "linux"[/FONT]
[FONT="]MACHINE = "dm7020"[/FONT]
[FONT="]DISTRO = "opendreambox"[/FONT]
[FONT="]DISTRO_VERSION = "1.4.0"[/FONT]
[FONT="]TARGET_FPU = "soft"[/FONT]
[FONT="]DB600PVR:[/FONT]
[FONT="]* Usable to HDD or flash[/FONT]
[FONT="]MACHINE = "dm600pvr"[/FONT]
[FONT="]************************************************** ****[/FONT]
[FONT="]ALL DECODER ( same options not present to IPBOX200s - DM500 - DM5620 ):[/FONT]
[FONT="]Buttons:[/FONT]
[FONT="]----------[/FONT]
[FONT="]* BLUE - Blue-Panel[/FONT]
[FONT="]* 2x BLUE - Emu-Panel[/FONT]
[FONT="]* YELLOW - Plugins[/FONT]
[FONT="]* YELLOW > 1 sec. ..start plugin called sifteam (rename any plugin you want use with this option)[/FONT]
[FONT="]* BLUE - YELLOW > Addons[/FONT]
[FONT="]* BLUE - GREEN > Scripts[/FONT]
[FONT="]* RED - WEEKEPG (thanks to MaxZ4)[/FONT]
[FONT="]* GREEN - subservices[/FONT]
[FONT="]*[/FONT]
[FONT="]Features:[/FONT]
[FONT="]* Advanced FIREWALL with graphics start/stop/configuration[/FONT]
[FONT="]* Advanced SWAP file configuration, you can set swap in USB, CF or HDD (16mb or 32 mb)[/FONT]
[FONT="]* Advanced DNS with graphics start/stop/configuration[/FONT]
[FONT="]* Advanced FILES visualizations[/FONT]
[FONT="]* Advanced BACKUP with graphics start/stop/configuration[/FONT]
[FONT="]* Set CROND start at any boot[/FONT]
[FONT="]* Advanced crond system configuration[/FONT]
[FONT="]* Set SAMBA start at any boot (7000 have to install samba-plugin)[/FONT]
[FONT="]* Advanced WEEKEPG options ( ...if you want use standard, set to blue-panel->options->weekepg )[/FONT]
[FONT="]* Automount HDD USB CF[/FONT]
[FONT="]* Advanced HDD ..set sleep and acoustic options[/FONT]
[FONT="]* Advanced SCRIPT options for personal set[/FONT]
[FONT="]* Advanced OpenVpn with graphics start/stop/configuration[/FONT]
[FONT="]* Advanced AMULE with graphics start/stop[/FONT]
[FONT="]* Advanced TORRENT with graphics start/stop/configuration (thanks to MaxZ4)[/FONT]
[FONT="]* Set personal AUTOSTART program[/FONT]
[FONT="]* Color set to RGB from default ( for lcd TV)[/FONT]
[FONT="]* Simple Set directory for picon[/FONT]
[FONT="]* Inserted DM7020 Network Fix[/FONT]
[FONT="]Display Function:[/FONT]
[FONT="]-------------------[/FONT]
[FONT="]From 1.8.5 more of this information is settable from Menu-Advanced..[/FONT]
[FONT="]* Set zap without OSD (if press OK return OSD)[/FONT]
[FONT="]* Set OSD always on when OK is pressed (required from nokia9k8)[/FONT]
[FONT="]* Display Snr, Agc, Ber[/FONT]
[FONT="]* Display video information[/FONT]
[FONT="]* Display frequency, polarization, symbol rate[/FONT]
[FONT="]* Display emu in use[/FONT]
[FONT="]* Display service providers name[/FONT]
[FONT="]* Display CaID, ProvID, PID (you can hide from options)[/FONT]
[FONT="]* Display Decoding Source (you can hide from options)[/FONT]
[FONT="]* Display long date format[/FONT]
[FONT="]* Picon, already inserted to enigma code (thanks to jlmota)[/FONT]
[FONT="]* SkinPreview (thanks to jlmota)[/FONT]
[FONT="]* Skin Lite/Full, when Lite ..if no OSD present, and press OK see Full (thanks to tension for help)[/FONT]
[FONT="]* skin by porto for Dreambox[/FONT]
[FONT="]* skin by vali (adapted from me) for Ipbox[/FONT]
[FONT="]EMU:[/FONT]
[FONT="]------[/FONT]
[FONT="]* Set Default CAM[/FONT]
[FONT="]* Set channel CAM[/FONT]
[FONT="]* Set provider CAM[/FONT]
[FONT="]* Stop active CAM[/FONT]
[FONT="]* Set off/on and hours/minutes for autorestart CAM[/FONT]
[FONT="]*[/FONT]
[FONT="]Addons:[/FONT]
[FONT="]* Internet addons download[/FONT]
[FONT="]* Manual addons install[/FONT]
[FONT="]* Remove installed addons[/FONT]
[FONT="]*[/FONT]
[FONT="]Misc:[/FONT]
[FONT="]* Italian, English language[/FONT]
[FONT="]* Many language in download[/FONT]
[FONT="]* Skin default - vali_n07[/FONT]
[FONT="]* Picon is already installed (DB7000, IPBOX250, IPBOX350 ..have only default.png)[/FONT]
[FONT="]* Several Plugins/Games/Addons installed[/FONT]
[FONT="]* IPBOX250S ...have to set mID 25[/FONT]
[FONT="]* IPBOX350S ...have to set mID 26[/FONT]
[FONT="]* IPBOX200S ...autoset mID[/FONT]
[FONT="]* IPBOX200S have UHF in/out[/FONT]
[FONT="]* IPBOX200S ...for free memory (if is necessary):[/FONT]
[FONT="] 1) Go to free channel[/FONT]
[FONT="] 2) Click to "Free Memory"[/FONT]
[FONT="] ...now is possible to start/stop install/remove visualize script ecc..[/FONT]
[FONT="]************************************************** ******[/FONT]
[FONT="]THANKS TO:[/FONT]
[FONT="]--------------[/FONT]
[FONT="]DB500 > frog68.[/FONT]
[FONT="]DB7000 > I, MaxZ4, adamo49.[/FONT]
[FONT="]DB5620 > MaxZ4.[/FONT]
[FONT="]DB7020 > Ngc1927[/FONT]
[FONT="]IPBOX200S > Genge Voodo3 Ngc1927[/FONT]
[FONT="]IPBOX250S > astemio [/FONT]
[FONT="]IPBOX350S > I, genge, voodo3,lorenzo64,neri73[/FONT]
[FONT="]All IPBOX > ..special thanks to sandali for its branch of development ..and Blakskettle for any info.[/FONT]
[FONT="]FOR ALL > porto, jlmota, MaxZ4 ...and other?[/FONT]
[FONT="]Thanks to all and good fun [/FONT]
[FONT="]VARIOUS:[/FONT]
[FONT="]-----------[/FONT]
[FONT="]This image is based, beyond that my "much" code and hard work, to Dream-cvs, parts of old Hydra [/FONT]
[FONT="]source (EMU/ADDONS ...emubroker is this) to little EasyEmu parts ...and other?[/FONT]
[FONT="]************************************************** ****************[/FONT]
[FONT="]ATTENZIONE:[/FONT]
[FONT="]QUESTO FIRMWARE NON CONTIENE CHIAVI, NE' EMULATORI, NE' [/FONT]
[FONT="]INDIRIZZI PER SCARICARE MATERIALE ILLEGALE DI NESSUN TIPO.[/FONT]
[FONT="]L'AUTORE NON E' RESPONSABILE IN NESSUN MODO DELL'USO CHE [/FONT]
[FONT="]GLI UTENTI NE FARANNO, DI LORO SPONTANEA VOLONTA'.[/FONT]
[FONT="]THIS FIRMWARE DOES NOT INCLUDE KEYS, NOR EMULATORS, NOR [/FONT]
[FONT="]URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.[/FONT]
[FONT="]AUTHOR IS NOT RESPONSIBLE IN ANY WAY FOR WHAT[/FONT]
[FONT="]THE USERS WILL DO WITH THIS FIRMWARE.
[/FONT] [FONT="]************************************************** ****************
Grazie RAGAZZIIIIIIIIIIIIIII
[/SIZE][/URL][/FONT]
[/FONT]
[FONT="]*[/FONT]
[FONT="]EMU:[/FONT]
[FONT="]*[/FONT]
[FONT="]*[/FONT]
