Nel file che ho scaricato (.zip) ci sono due file, uno .pib e l'altro .rom (servono entrambi per aggiornare il firmware) ma non ci sono le istruzioni; la procedura è riportata sommariamente solo nel manuale, dove c'è scritto:
Local Device(s) on your computer: This shows all local Powerline Ethernet Adapter found connected to the computer‟s LAN card. In most cases, only one device will display in this panel. Click and select the local device shown on the screen then click “Connect” tab to manage the Powerline Ethernet Adapter. The status message will be shown above the “Connect” button indicates that your PC is connected to the same device. Once the chosen Powerline Ethernet Adapter is properly connected, this Management Utility will automatically scan the power line periodically for any other existing powerline devices. You can upgrade the version of firmware for the device by clicking the Upgrade Firmware button which is shown as below.
PIB: Parameter Information Block. It contains configuration values that establish device network identity, general capabilities and operational modes.
NVM: None-volatile memory. It is used for upgrading the firmware.
If you want to upgrade the version of firmware for the device, please select appropriate Firmware and PIB files together. New firmware versions and PIB files are posted at
www.tp-link.com and can be downloaded for free.
To upgrade the device's firmware, follow these instructions:
1. Download PIB file and firmware upgrade file from the TP-LINK website (
www.tp-link.com).
2. Enter the path name or click Browse… to select the downloaded files on the computer into the corresponding blanks.
3. Click the OK button.
Note: Do not turn off the device while the firmware is being upgraded. The device will reboot after the Upgrading has been finished.
